4 members (Otto Skorzeny, Steelonsteel, k2handyman, Woodcmiami), 116 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
#719796 02/10/2011 5:11 AM
How can a person determine the displacement of the pontiac engines used 55-59? Thanks Russ
If they are from a GMC truck there is a serial number stamped into the block on the right side near the oil pan. The first 3 numbers are the displacement of the engine. I don't know if car engines have this or not.
how about by the year and or casting numbers?
1955 287
1956 316
1957 347
1958 370
1959 389
1958 and 1959 gmc engines were debored pontiac 370 and 389 to come up with 336 inches.
how does one debore an engine?
ron
One doesn't. The factory does. I suppose if you wanted a smaller cubic inch motor, you could install sleeves in the cylinder bores.
I would imagine that the 59 version would have had a little torque due to to longer stroke and the smaller bore.
I was just teasing about the deboring(just sounds funny)
ron
