5 members (tclederman, FAST55, Joe H, lumbersawyer, 1 invisible), 69 guests, and 2 robots.
Topics128,023
Posts1,055,367
Members48,420
#719203 02/08/2011 5:43 AM
I have a 1940 1.5 ton Chevy that I am currently restoring. The heater inside the cab is a small radiator with a fan at the back and is labeled Goodrich. I have seen alot of pictures of other styles and brands but none of them have been Goodrich. It would be great to know if this is aftermarket or stock option and any other details. Thanks
tracermc #719287 02/08/2011 4:57 PM
It is likely an aftermarket unit. Most heaters back at that time were available from aftermarket sellers, (Sears, Wards, local auto dealers. etc.) and tire dealers. It is a pretty sure bet that Goodrich did not make the heater and it may in fact be the same as some of the other brands available. Up into the fifties there was a heater delete option and radios were not supplied as standard either. How things have changed. Now you must purchase an entire option group to get the one or two items you really want.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #719583 02/09/2011 1:00 PM
I would like to see a picture of that heater Tracer, I'm compiling a folder for old heaters.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Denny Graham #719606 02/09/2011 3:19 PM
Brad Allen #719706 02/09/2011 10:52 PM
Thanks Brad, I'll add those to my heater files, preciate that. Make for a real cool looking heater.
DG
Denny G
Sandwich, IL
Denny Graham #719745 02/10/2011 1:27 AM
Ex Hall Monitor
Ex Hall Monitor
Betcha can't get one for $18.95 any more. grin
Tiny #719748 02/10/2011 1:35 AM
That is pretty. Denny do you have the ones you have posted anywhere?
neilroy #720150 02/11/2011 4:09 PM
Thanks for the pics. I will put it back together and post some as well. Mine seems to be either older or not as art deco styled because the radiator sits upright and the front of the radiator is exposed. Still a very simple unit.
tracermc #720217 02/11/2011 9:55 PM
They offered a range of styles at different price points I tried to do some research on them and there is not a lot out there. They do pop up occassionally on eBay so I usually save the pictures or details. Of the two I owned one was ornate the other quite a bit less art-deco themed with just a single wide chrome band.
Moderated by  ndkid275, Phak1
