| | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 11 New Guy | | New Guy Joined: Oct 2010 Posts: 11 | I have a 1940 1.5 ton Chevy that I am currently restoring. The heater inside the cab is a small radiator with a fan at the back and is labeled Goodrich. I have seen alot of pictures of other styles and brands but none of them have been Goodrich. It would be great to know if this is aftermarket or stock option and any other details. Thanks | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | It is likely an aftermarket unit. Most heaters back at that time were available from aftermarket sellers, (Sears, Wards, local auto dealers. etc.) and tire dealers. It is a pretty sure bet that Goodrich did not make the heater and it may in fact be the same as some of the other brands available. Up into the fifties there was a heater delete option and radios were not supplied as standard either. How things have changed. Now you must purchase an entire option group to get the one or two items you really want. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I would like to see a picture of that heater Tracer, I'm compiling a folder for old heaters. Thanks, Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks Brad, I'll add those to my heater files, preciate that. Make for a real cool looking heater. DG
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Betcha can't get one for $18.95 any more.
| | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | That is pretty. Denny do you have the ones you have posted anywhere? | | | | | Joined: Oct 2010 Posts: 11 New Guy | | New Guy Joined: Oct 2010 Posts: 11 | Thanks for the pics. I will put it back together and post some as well. Mine seems to be either older or not as art deco styled because the radiator sits upright and the front of the radiator is exposed. Still a very simple unit. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | They offered a range of styles at different price points I tried to do some research on them and there is not a lot out there. They do pop up occassionally on eBay so I usually save the pictures or details. Of the two I owned one was ornate the other quite a bit less art-deco themed with just a single wide chrome band. | | |
