4 members (Cletus1950, Uncles51, dt235sd, Gray_Ghost), 106 guests, and 2 robots.
Topics128,174
Posts1,057,048
Members48,458
Picked up a 52 that has had most of the cab redone, original 6 rebuilt, and other things forward of the bed done. I am starting from the rear and working toward what's been done now and have ran into a couple of questions:
In the process of grinding off the rust and repainting the frame, I've made it to the axle. At this time, the bumpers that are above the axle are sitting on the axle as the shocks aren't put on. While looking at the leaf springs, I can't figure out if the axle has been changed out and the leafs have been put under the axle rather than over the top. I put the shock back in for reference, but it will have to be replaced as I can push it together by hand.
Any assistance is appreciated and here is the picture:
https://picasaweb.google.com/lh/photo/W0UoLuWEcp1uhb_lfLeq9w?feat=directlink
Have a look at the assembly amnual. You should get a pretty good idea of what things should look like.
1951 1 Ton Completed
Brad I Like your Exhaust Hanger
1954 3600 With 1950's Powers of St Louis Utility Bed.
My truck
Brad, I believe that picture is helping, but it brought up another question as well. Does your gear housing sit in the center, or is it off to one side more than the other? Mine sits more to the driver's side and I'm beginning to think that the axle was flipped over, causing where the leafs would sit to be on the bottom. I think the guy I bought the truck from was trying to lower it. This would also explain only having 3 or 4 leafs in my leaf spring setup.
delta - your axle isn't flipped or the vent nub wouldn't be on top as it is in the pic - the pots are always off center, with one axle longer than the other - the spring mount pads were moved so the springs could be put under rather than in the original position above the axle, and that's why the bumpers are down on the axle, the shocks will not support the truck! - an altogether non-functional setup, you may want to consider restoring the correct configuration .... may be part of why the PO gave up on the project wink
Bill, you are 100% correct! Looks like I've got some welding to do. What kills me is that I can't even tell where the mount pads were removed!
You may have a Task Force era rear end. That is how they mount.
Is that why I've only got the three leafs? Any links to pictures so I can see how they're supposed to be set up?
All of you are a wealth of info! Thanks!
