2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 36 | Is the inside diameter of a 47-59 fuel neck hose 1 3/8". I was told it is but don't have one to check. If so where could i get one. I need to replace the hose on a 66 carryall but can't find one anywhere, it's 1 3/8". | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | have you tried NAPA? locally the correct size fuel hose is available by the piece, you cut to length
Bill | | | | | Joined: Sep 2001 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 36 | Nobody carries 1 3/8" fuel neck hose, it's an odd size with no demand. That's why I was trying to find out if 47-59 had the same inside diameter. Then I would be able to go to a restoration site and possibly find some. | | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | Ross The 47-48 connection hose is completely different from the later ones. My '48 takes a 2" ID piece of hose. Which year are you working on? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | On a my 50 it is 1 3/8 Good Luck | | | | | Joined: Sep 2001 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 36 | Dads50, that is what I need 1 3/8" for my 66 carryall were can I get some. Just need a piece 3 1/2" long. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | If you could not locate at your local auto parts store you could try and belt and hose shop. I had a local shop make me up some hoses for my remote oil canister.
maybe you can try chev's of the 40's. They are located in your neck of the woods.
All the vendors carry the kits
Good Luck
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A 1954 Suburban is 2¼". I found it at a parts store. It was a remnant and I had to buy the whole 8" of it. You might call around to local flaps and have them check for a remnant. | | |
