5 members (SNOYL, Forty9, Ponchogl, Hawkman, 1 invisible), 91 guests, and 1 robot.
Topics128,052
Posts1,055,729
#71918 01/19/2007 3:05 AM
Apprentice
Apprentice
Hi all. I am wondering if there is a backyard method of checking flywheel runout. I have just installed my 168 tooth flywheel into my '54 motor and do not have the necessary tools to accomplish this task. Can I get away with installing the flywheel and torqueing the bolts??? Thanks.
#71919 01/19/2007 4:53 AM
There's no real need to check runout. Just reassemble and torque the bolts. I like to run the pressure plate bolts down gradually, not all at once, to prevent distorting the plate and disc.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#71920 01/19/2007 4:07 PM
Apprentice
Apprentice
Cool & thanks. Should the flywheel be turned for "trueness"?
#71921 01/19/2007 4:20 PM
You should have the flywheel "turned" when you install a new clutch disk and pressure plate... otherwise you might get that grabby feeling.
Another quality post.
Real Trucks Rattle
