| | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#71918 01/19/2007 3:05 AM | Joined: Dec 2006 Posts: 27 Apprentice | | Apprentice Joined: Dec 2006 Posts: 27 | Hi all. I am wondering if there is a backyard method of checking flywheel runout. I have just installed my 168 tooth flywheel into my '54 motor and do not have the necessary tools to accomplish this task. Can I get away with installing the flywheel and torqueing the bolts??? Thanks. | | |
#71919 01/19/2007 4:53 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | There's no real need to check runout. Just reassemble and torque the bolts. I like to run the pressure plate bolts down gradually, not all at once, to prevent distorting the plate and disc. Scott | | |
#71920 01/19/2007 4:07 PM | Joined: Dec 2006 Posts: 27 Apprentice | | Apprentice Joined: Dec 2006 Posts: 27 | Cool & thanks. Should the flywheel be turned for "trueness"? | | |
#71921 01/19/2007 4:20 PM | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | You should have the flywheel "turned" when you install a new clutch disk and pressure plate... otherwise you might get that grabby feeling.
