4 members (BC59, Gdads51, carbking, papas52), 89 guests, and 3 robots.
Topics128,181
Posts1,057,180
Members48,465
hello,i saw a post for this question before, but i do not know the weight of the truck for the person that was asking. just found out that my truck is in fact a 2 ton. i ordered 1 1/2 ton king pins and they are too small. i cant find any for my year (51) in a 2 ton online. please let me know if you have any info. thanks -DVZ
3B Offline
Hy dvzdeathtrap, could you give us your truck series, or your serial number, the terms 1 1/2 & 2 ton are too vague, too much chance for errors.
I got a set from chev's of the 40's for my 46 2 ton and they asured me they were the right ones. They weren't, they were to small and I had to send them back.
I see these king pin sets on ebay alot. There's a few NOS there now.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Rare parts in Stockton Ca has them, I got a set for a 53 6400 series ( 2 ton ) they said from a 3/4 to 2 ton were all the same, what happened is they sent me .010 oversize the first go round, so I would call them and have them check a set before shipping.
Man I like your "pickup". Very cool.
According to the 48-51 Truck Shop Manual the 2 ton models had larger (1.109") king pins than 3/4-, 1- and 1 1/2-ton conventional models which did share the same .921 diameter.
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0316.htm
Good luck!
Professional Novice
thanks for all the replies guys. i'm just going to pull the old ones out and measure them. this way i am certain i am getting the right ones. BTW- I have a set for a 1 1/2 ton now if anyone needs them. i will post them in the parts for sale area. -DVZ
My guess is that you will need NAPA #2621475. This corresponds to the interchange number of 3691111, which is listed as '46-53 2 ton. As mentioned above, the 2 ton model is a seperate beast than the 1.5 ton and smaller. Once you remove them we can figure out if you need oversized or not and come up with more numbers.
Good luck, Jeff
My 1953 Chevrolet
1947.1 Gallery
thanks jeff. i didn't think napa would have them. there is one right down the street from me. -DVZ
I just purchased a set for my 1.5 ton at NAPA. When we were researching them their computer listing displayed the sizes enabeling me to order the correct ones. Possibly they can help you.
Hi, been very long time since being on forums here and dropped in to check out the Big Bolts again. Wanted to say I have two sets of kingpins, one in orig GM box, kinda ruff that might be for 2-ton. I can look in garage and take pix if interested. One kit has no box, so not sure what it is, other than GM. I can measure also. I'ld take $20 for the pair (2 sets) if you wanted. Email me at [email protected] for easier correspondence. I see fellas having the same issues with rebuilds as in past, so not much has changed. I got out of the truck mode and into tractors now.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
24601
24601
Hey grumpy!! Good to see you back in here -- even if only for a drive by!
Hope all is well,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
G.L. Perry !, Man that's a "blast from the past". Howya been Dude. Been a long time. Glad to see you drive by. Still have any Big Bolts.
Spanky Hardy
1950 GMC 250 1-Ton
Hi Spanky, NO, sold all my trucks and last COE project I threw in all the extra engines and stuff I had for Bolts. I got into tractors, Minneapolis-Molines and now doing more with Garden tractors of any brand. Seems GT's are the "newest" hot item at the shows. Don't do any "pulling" with either size. Now, thinking I might get out of those tractors too. I do miss my 54. I sold it, was offered later. Went to look at it, but guy had it banged up a bit and was dissappinted in condition, so forced myself to say NO! Now thinking of buying another, just better shape to start.
G.L. Grumpy's
Old Iron Ranch
I just saw there is a set of 2 ton king pins NOS on ebay now, ebay item number 360329783305. Hope that helps.
Rob
