5 members (Bill Hanlon, LAROKE, rfs56trk, Maybellene, klhansen), 140 guests, and 1 robot.
Topics128,034
Posts1,055,544
Members48,425
Changing the ratio in a '40 1 1/2 ton rear end. Finally got through the pinion switch. Not quick and easy. Now the bolts are out of the ring gear and it appears that it won't come off without some heat like a flywheel ring gear. Could really use some advise from someone who has done this before. Thanks, David
3B Offline
Hy dmart, according to the maintenance manual, once all of the bolts are removed the ring gear should be able to be removed from the right side of the differential case by "tapping with a soft faced hammer", hope that helps.
Thanks 3B,
I did do some tapping on it. Maybe it is time to get a tad bit more aggresive. Will give it a try again.
3B,
Thanks again. That did the trick. Tapping gently is really...drive firmly.
Where did you get your replacement gears?
1951 1 Ton Completed
Truckernix,
I bought the gears from Vintage Auto Parts Inc. , vapinc.com , 800-426-5911
Never bought from them before but it all went fine. NOS clean and I paid $ 375.00 for the set.
