8 members (GRNHydra, David Bush, JW51, Oswald, Otto Skorzeny, Wally / Montana, Guitplayer, NJC),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,060 Posts1,055,838 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#71634 01/14/2007 2:12 PM | Joined: Aug 2006 Posts: 59 Member | | Member Joined: Aug 2006 Posts: 59 | We are going through the motor in my son's 1970 Z-28 . I've rebuilt many SBC engines over the years and Never ran across this ; the cam will not come out of the block no more than 1 inch . I think one of the rear cam bearings has spun . If so how can the now be removed?
1965 C-10 fleetside shortbed BLACK 82 c-10 longbed 6 cyl. 58 Lincoln 2-dr coupe Black w/white & blk. 59 lincoln 4-dr. parts car
#71635 01/14/2007 2:19 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | fuel pump & pushrod removed? You can remove the rear cam plug & get on the backside. Brian | | |
#71636 01/14/2007 2:20 PM | Joined: Jun 2005 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 46 | did you remove the fuel pump push rod? | | |
#71638 01/16/2007 2:13 AM | Joined: Aug 2006 Posts: 59 Member | | Member Joined: Aug 2006 Posts: 59 | Sorry guys , this motor is runinng a electric pump and I never thought about the block mounted pump . My head jumped time on this one . Cam out and in the junk pile. Thanks .
#71639 01/16/2007 8:40 AM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Had the same thing (almost) happen when I changed the cam on the Z24 years ago. Book said to remove the distributor, but the engine doesn't have one. Took me a while to realise the plug covering the dizzy mount also had the upper shaft for the oil pump. Cussed GM engineers for a while before I figured it out.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
