3 members (dunfire, 78buckshot, Hotrod Lincoln), 90 guests, and 2 robots.
Topics128,055
Posts1,055,783
#71634 01/14/2007 2:12 PM
We are going through the motor in my son's 1970 Z-28 .
I've rebuilt many SBC engines over the years and Never ran across this ; the cam will not come out of the block no more than 1 inch .
I think one of the rear cam bearings has spun . If so how can the now be removed?
1965 C-10 fleetside shortbed BLACK
82 c-10 longbed 6 cyl.
58 Lincoln 2-dr coupe Black w/white & blk.
59 lincoln 4-dr. parts car
#71635 01/14/2007 2:19 PM
fuel pump & pushrod removed? You can remove the rear cam plug & get on the backside. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#71636 01/14/2007 2:20 PM
did you remove the fuel pump push rod?
#71638 01/16/2007 2:13 AM
Sorry guys , this motor is runinng a electric pump and I never thought about the block mounted pump . My head jumped time on this one .
Cam out and in the junk pile.
Thanks .
#71639 01/16/2007 8:40 AM
Had the same thing (almost) happen when I changed the cam on the Z24 years ago. Book said to remove the distributor, but the engine doesn't have one. Took me a while to realise the plug covering the dizzy mount also had the upper shaft for the oil pump. Cussed GM engineers for a while before I figured it out.
