| | | Forums66 Topics128,181 Posts1,057,177 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | hello,i saw a post for this question before, but i do not know the weight of the truck for the person that was asking. just found out that my truck is in fact a 2 ton. i ordered 1 1/2 ton king pins and they are too small. i cant find any for my year (51) in a 2 ton online. please let me know if you have any info. thanks -DVZ | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy dvzdeathtrap, could you give us your truck series, or your serial number, the terms 1 1/2 & 2 ton are too vague, too much chance for errors. | | | | | Joined: Feb 2010 Posts: 478 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 478 | I got a set from chev's of the 40's for my 46 2 ton and they asured me they were the right ones. They weren't, they were to small and I had to send them back. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I see these king pin sets on ebay alot. There's a few NOS there now. | | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | Rare parts in Stockton Ca has them, I got a set for a 53 6400 series ( 2 ton ) they said from a 3/4 to 2 ton were all the same, what happened is they sent me .010 oversize the first go round, so I would call them and have them check a set before shipping. | | | | | Joined: Nov 2000 Posts: 1,972 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,972 | Man I like your "pickup". Very cool. According to the 48-51 Truck Shop Manual the 2 ton models had larger (1.109") king pins than 3/4-, 1- and 1 1/2-ton conventional models which did share the same .921 diameter. http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0316.htm Good luck!
Professional Novice
| | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | thanks for all the replies guys. i'm just going to pull the old ones out and measure them. this way i am certain i am getting the right ones. BTW- I have a set for a 1 1/2 ton now if anyone needs them. i will post them in the parts for sale area. -DVZ | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | My guess is that you will need NAPA #2621475. This corresponds to the interchange number of 3691111, which is listed as '46-53 2 ton. As mentioned above, the 2 ton model is a seperate beast than the 1.5 ton and smaller. Once you remove them we can figure out if you need oversized or not and come up with more numbers. Good luck, Jeff | | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | thanks jeff. i didn't think napa would have them. there is one right down the street from me. -DVZ | | | | | Joined: Nov 2010 Posts: 8 New Guy | | New Guy Joined: Nov 2010 Posts: 8 | I just purchased a set for my 1.5 ton at NAPA. When we were researching them their computer listing displayed the sizes enabeling me to order the correct ones. Possibly they can help you. | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Hi, been very long time since being on forums here and dropped in to check out the Big Bolts again. Wanted to say I have two sets of kingpins, one in orig GM box, kinda ruff that might be for 2-ton. I can look in garage and take pix if interested. One kit has no box, so not sure what it is, other than GM. I can measure also. I'ld take $20 for the pair (2 sets) if you wanted. Email me at [email protected] for easier correspondence. I see fellas having the same issues with rebuilds as in past, so not much has changed. I got out of the truck mode and into tractors now.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Nov 1995 Posts: 5,744 24601 | | 24601 Joined: Nov 1995 Posts: 5,744 | Hey grumpy!! Good to see you back in here -- even if only for a drive by!
Hope all is well, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | G.L. Perry !, Man that's a "blast from the past". Howya been Dude. Been a long time. Glad to see you drive by. Still have any Big Bolts. | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Hi Spanky, NO, sold all my trucks and last COE project I threw in all the extra engines and stuff I had for Bolts. I got into tractors, Minneapolis-Molines and now doing more with Garden tractors of any brand. Seems GT's are the "newest" hot item at the shows. Don't do any "pulling" with either size. Now, thinking I might get out of those tractors too. I do miss my 54. I sold it, was offered later. Went to look at it, but guy had it banged up a bit and was dissappinted in condition, so forced myself to say NO! Now thinking of buying another, just better shape to start.
| | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | I just saw there is a set of 2 ton king pins NOS on ebay now, ebay item number 360329783305. Hope that helps. Rob | | |
