2 members (Gdads51, UtahYork),
113
Mod | | | Forums66 Topics128,150 Posts1,056,985 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 144 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 144 |
Dave www.fallenherosdreamride.orgall give some MY SON GAVE ALL The fallen hero's dream ride is a 1951 Chevrolet 3100 with original 216 In memory of LCpl Phillip Vinnedge USMC KIA 10/13/2010 Afghanistan
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | A factory option that was about as rare as hen's teeth (on a truck).
There was no factory option "split manifold" or dual exhaust option for a truck 216/235/261. My bet is that the only GM 235 dual-exhaust manifold was available on 53-55 Corvette 235 engines.
Maybe someone knows the Corvette manifold's casting code.
However, it was not uncommon for shops/services to split a manifold and graft-on another down-pipe and make a dual-exhaust manifold.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The manifold shown is for a 53-55 235 Corvette engine. The intake manifold that was used with this exhaust manifold is aluminum and had 3 side draft carburetors on it. Don | | | | | Joined: Jan 2011 Posts: 144 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 144 | Thanks for the info. It is very surprising to me for as original as this farm truck appears to be (with only 28K miles), that someone would have put on the split manifold and dual exhaust.
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Wow that's an interesting manifold ya' got there. It would certainly appear to be a factory original 2-piece casting. All of the 6-cyl Corvette manifolds I've ever seen were cast in one piece. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | It looks to me like the casting number is 3836108. That is the correct casting number for the Corvette manifold. | | | | | Joined: Jan 2011 Posts: 144 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 144 | I had a typo in my original post. The casting number is 3836108.
I'll be pulling it off shortly and post additional pictures.
| | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | The Corvette split manifold is a 1 piece exhaust manifold. They were a popular "hop up" item. I have seen an ad where they sold pretty cheaply back then. I think the article floating around about "soup that chevy" from 55 Hot Rod magazine has that ad. | | | | | Joined: Jan 2011 Posts: 144 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 144 |
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: May 2004 Posts: 11 New Guy | | New Guy Joined: May 2004 Posts: 11 | NO EXPERT HERE BY NO MEANS - I HAVE NEVER SEEN A ONE PEACE EXHOUST MANIFOLD ON A 53/54 VETTE AND I HAVE SEEN A FEW. THEY ALL HAD CAST IRON FACTRORY HEADERS
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | That is a correct dual exhaust manifold for 53/54 corvette.There is one listed on ebay of a starting price of $650 .The guys that say corvette are correct,That's sweet !!! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The bottom line is you have a very desirable piece. I have the intake manifold and carburetor set up and have been searching for years for a good deal on the exhaust manifold to go with it. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Check the numbers on the engine and tranny numbers also. Make sure someone didn't swap the whole thing out with a Corvette engine and/or tranny. You might be "In The Money" with that is complete. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The first pictures show the oil distributor on the side of the block. No question that its a early low psi engine. | | | | | Joined: Jan 2011 Posts: 144 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 144 | The block numbers show it as a '51 216.
It's tempting to raise some cash by selling the manifold, but I think it's going back on.
I have lots of pictures on the website. If you see anything else that does not look original, I'd appreciate hearing about it.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | That is a real nice looking truck.
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Your intake manifold, casting 3835527 is listed for a 216.
The 216 and 235 manifolds are not interchangeable because the heat box is different.
It looks like someone relocated the stud on the intake to make it work. Also the gasket between the manifolds is very large and looks thicker on one side.
I have the same 235 53-55 vette exhaust manifold, casting # 3836108. Wanted to use it with my 216 2x1 tattersfield intake, couldn't because the heat box didn't line up.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | Tom Langdon of www.stoveboltengineco.com offered to trade a set of Fenton headers for the vette split manifold. Seemed like a lop-sided trade to me but I am sure the offer probably still stands. | | | | | Joined: Feb 2003 Posts: 1,379 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,379 | It would be nice if someone would reproduce them as I would rather have the corvette manifold instead of the fentons I presently have on the 37,one of those would be perfect since I am trying to make the 235 look like a 216 and factory casting numbers would fool most people. | | | | | Joined: Feb 2003 Posts: 1,379 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,379 | I put out some feelers for one of those manifolds and they are not cheap,I think I will be buying the heat kit for the intake since they are only around 40 dollars. I found one that needed repairs for 700.00 and a mint one for 995.00,just missed one for 550.00 shipped so I will need to start putting some money away each week if I ever want to buy one and then hope they dont go up in price during the time I am saving up. | | |
