4 members (66flea, k2handyman, 68ironhead, Jay R), 117 guests, and 2 robots.
Topics128,056
Posts1,055,796
#714902 01/25/2011 3:58 AM
any significance that the cam thrust plate on my 235 (3839511) has three bolts (two 7/16 one 1/2) holding the plate on instead of two screws as mentioned in the 54 manual
any methods of getting the two countersunk screws out that hold the front plate to the block out? i've already broken one screw driver. maybe let the machine shop do it?
1963 c10
Take a punch and tap one side of the countersunk screws counter-clockwise with a hammer, once you get them to turn even a little bit a screwdriver will get them out.
Don't know about the thrust plate, maybe one was drilled out to a larger size after being broken off?
1946 Chevy 1/2-Ton
More pix on Photobucket
Sometimes I forget where I left myself....
Either use a Propane torch to heat the screws and expand them a little, or use an impact driver to shock the screws loose. If you're working through the holes in a fiber timing gear, be careful not to damage the gear with the torch. If you're planning to replace the timing gear, just break it off with a big pry bar to give yourself more working room.
Jerry, I think he has the cam out, he just can't get the back half of the timing cover off, also don't forget there are two bolts inside from the back, up inside the oil pan.
And aren't there three countersunk screws ?
Not just two ?
1946 Chevy 1/2-Ton
yes the cam is out
only found two screws
i have the bolts from inside out already
i'll try the impact or the punch method
thanks
1963 c10
If you clean it up, I think you will find those screws are staked. I was told this about my 216 and they were staked. Taking care of that made them easier to remove.
1951 1 Ton Completed
I use a hand impact tool with a flat blade screw driver bit. One smack with the hammer their loose. Mine is similar to this
http://www.mytoolstore.com/klein/70220.html. There should be 3 flat head screws and 4 bolts, two inside and two outside
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
cleaned it up found all three screws staked. taking it to the machine shop tomorrow to see if it is any good,
i'll let you know the prognosis
1963 c10
