1 members (Hotrod Lincoln),
73
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | any significance that the cam thrust plate on my 235 (3839511) has three bolts (two 7/16 one 1/2) holding the plate on instead of two screws as mentioned in the 54 manual
any methods of getting the two countersunk screws out that hold the front plate to the block out? i've already broken one screw driver. maybe let the machine shop do it?
1963 c10 | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Take a punch and tap one side of the countersunk screws counter-clockwise with a hammer, once you get them to turn even a little bit a screwdriver will get them out. Don't know about the thrust plate, maybe one was drilled out to a larger size after being broken off?
| | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Either use a Propane torch to heat the screws and expand them a little, or use an impact driver to shock the screws loose. If you're working through the holes in a fiber timing gear, be careful not to damage the gear with the torch. If you're planning to replace the timing gear, just break it off with a big pry bar to give yourself more working room. Jerry
| | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Jerry, I think he has the cam out, he just can't get the back half of the timing cover off, also don't forget there are two bolts inside from the back, up inside the oil pan. And aren't there three countersunk screws ? Not just two ?
| | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | yes the cam is out only found two screws i have the bolts from inside out already i'll try the impact or the punch method thanks
1963 c10 | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you clean it up, I think you will find those screws are staked. I was told this about my 216 and they were staked. Taking care of that made them easier to remove. | | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | I use a hand impact tool with a flat blade screw driver bit. One smack with the hammer their loose. Mine is similar to this http://www.mytoolstore.com/klein/70220.html. There should be 3 flat head screws and 4 bolts, two inside and two outside | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | cleaned it up found all three screws staked. taking it to the machine shop tomorrow to see if it is any good, i'll let you know the prognosis
1963 c10 | | |
