6 members (Otto Skorzeny, R&S 51 GMC, KEVINSKI, Bill Hanlon, Swami29, Phak1), 100 guests, and 0 robots.
Topics128,125
Posts1,056,339
Members48,440
#714560 01/24/2011 12:57 AM
Hi folks- I just joined the forum today and wanted to let you know how much I appreciate the info posted here.
I'm looking at buying a 52 chevy, but I am not quite sure about some of it's details. It has 8 lug wheels and looks like a regular pickup (except the bed is gone and a wrecker/tow setup has been mounted), the owner isn't sure but I'm thinking it must be a 1 ton right? Besides the 8 lug stuff is there a difference between it and a 1/2 ton? Anything special I should be looking for or beware of when I go check it out tomorrow? Thanks- Greg
1951 GMC 250 Open Express
1968 C10 Suburban
1971 C20 Pickup
My Dad told me "Son, never hit a man in anger- unless you're certain you can get away with it"
Leo Offline
Moderator
Moderator
Hi Greg, welcome to the site. This is the welcome center, good place to introduce yourself, then acquaint yourself with the site and post in the appropriate forum. It's hard to know without seeing it if it is a one ton or 3/4 ton. Does it say 3600 or 3800 on the side of the hood? Some of the differences are hard to spot, rear end ratios are way different between the various weights.
Ask in the General Truck talk forum or in tons o' fun. You will get a better response.
Leo
Leo #714607 01/24/2011 4:13 AM
Welcome to the Bolt,name. Leo is correct about the info. Lots of guys on here can quote what you need right off the top of their head...but I ain't that good yet!
Good luck. Your in good company. Lots of info and great folks.
Hi i am in the same situation as you i just bought a 1952 chevy and it is a 8 bolt has no badges on it to tell me if it is a 3/4 ton or a 1 ton are you planning on saving the frame or switching it out
Creasy #714647 01/24/2011 6:19 AM
If there are no badges, the frame would tell you if it's a 1 ton. The one ton frame is significantly thicker and bigger. The steel in a 3/4 ton is 3/16 thick while that used in the 1 ton frame is 9/64. See The Chevy restoration kit for more details.
Welcome to the Bolt.
1951 Chevy 1-Ton Panel
Pictures of the restoration on Photobucket
RIP good friend.
The Ned #714796 01/24/2011 10:02 PM
Hi Greg,welcome to the 'bolt from Scotland.
As you can already see the guys are on the case.
Good luck with your new project.
More pix on Flickr.
Leo Offline
Moderator
Moderator
Better check those thicknesses, 3/16 is heavier than 9/64.
Leo #715378 01/26/2011 4:36 PM
OOPs... my bad.. 9/64 should be 7/32. Don't know how I managed to screw that one up. Thanks.
RIP good friend.
