0 members (),
67
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 8 New Guy | | New Guy Joined: May 2009 Posts: 8 | Do you put any oil,grease,etc on the main bolts or, do you torque them dry??
thanks, | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I haven't looked it up in the manual but I would say clean and oiled. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | All S.A.E. torque specs are written for clean threads lubed with 30 weight motor oil. If you're using a high-pressure lube such as Never-Seez, reduce the torque by about 5% or use the low side of the torque range specified. Jerry
| | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | Interesting test on TV show last weekend, comparing effect on torque of different lubes. ARP assembly lube gave most consistent results, while others gave dramatically differing results. Most came up short on bolt tension the first time torque was reached, and increased to near required value on susequent torquings (is that a word?). Of course, the torque/tension rig was supplied by ARP.
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | "I'm here to help- - - -and my product is just what you need!" The snake oil salesmen used the same sales pitch 150 years ago! Jerrry
