5 members (baldeagle, MNSmith, 46 Texaco, Shade Baby, 1 invisible), 94 guests, and 6 robots.
Topics128,018
Posts1,055,342
Members48,419
#714013 01/22/2011 12:55 AM
Do you put any oil,grease,etc on the main bolts or, do you torque them dry??
thanks,
gmbs #714016 01/22/2011 1:11 AM
I haven't looked it up in the manual but I would say clean and oiled.
1951 1 Ton Completed
truckernix #714027 01/22/2011 1:39 AM
Agreed, clean and oiled.
Bill Burmeister
gmbs #714052 01/22/2011 2:43 AM
All S.A.E. torque specs are written for clean threads lubed with 30 weight motor oil. If you're using a high-pressure lube such as Never-Seez, reduce the torque by about 5% or use the low side of the torque range specified.
Interesting test on TV show last weekend, comparing effect on torque of different lubes. ARP assembly lube gave most consistent results, while others gave dramatically differing results. Most came up short on bolt tension the first time torque was reached, and increased to near required value on susequent torquings (is that a word?). Of course, the torque/tension rig was supplied by ARP.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
starfire4 #714190 01/22/2011 4:50 PM
"I'm here to help- - - -and my product is just what you need!" The snake oil salesmen used the same sales pitch 150 years ago!
Jerrry
