Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Peggy M, Hotrod Lincoln, Otto Skorzeny), 193 guests, and 5 robots.
Topics128,284
Posts1,058,531
Members48,490
Page 26 of 177 1 2 … 24 25 26 27 28 … 176 177
What kind of truck?
~Jim
im sorry its a 53 3100.
*UNDER CONSTRUCTION*
1953 Chevrolet 3100 1/2 ton-previously abandoned resto.
My Project Bolt
I hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
Originally Posted by Silverado_9c3
removed my vent windows to make way for new ones...anyone have any experience with classic industries parts? are they any good? I am thinking of using their vent window assy's
I have never had any dealing with them. I have had good experience with LMC though. My vent windows would have the be really shot to spend almost $600 on new ones. I rebuilt mine and they look good as new. How bad are yours?
~Jim
The glass is shot (no big deal) the frames are rusted through and are basically falling apart. Classic industries sells the entire assy for 249.00.
My Project Bolt
Chances are they are made by the same mfg.
~Jim
Got the radiator un-clogged. Runs cooler now. Took for second test drive. Still no windshield in it yet. Replaced speedo needle. Blasted and painted former parking lights to be used as turn signals. Modified T5 shifter for dash/seat clearance.
http://s783.photobucket.com/albums/...%20pickup%20project/?albumview=slideshow
I finally have the cab painted. This week I hope to get the glass in it. I am putting all new rubber and tinted glass back in. The engine is almost complete. All I have left to do is mount the a/c compressor and the alternator. I went with a set of Vintage Air brackets to mount them. They are really nice billet brackets. Really hurt when I had to take a grinder to them to get them to fit – luckily its where you can’t see. Also had to have some spacers machined, those that came with it were not long enough and I didn’t want to stack up washers.
More pictures to follow…………………
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
John I enjoyed your pix.
My Project Bolt
I got the electric wiper motor working with the drivers side wiper only. I bought the "54 GMC" motor off ebay several years ago for the '54 pick up I was building. I found out it doesn't bolt up to a '54 GMC. It looks very similar to a Task Force Chevy electric motor but is clearly marked 6V. It had to be aft of and lower than the stock location to clear the cowl vent. Consequently, the arms need to be longer to reach it. I mounted it where the driver side reaches and I'll have to build an extended arm for the passenger side, with a bend to clear the glovebox.
Leo Offline
Moderator
Moderator
I picked up some parts at Bill's Truck Shop this morning. Still working on the doors and windows. He said to take the doors back off to install the rubber seals.
I will be installing doors, weather-strip and seals soon. I had not planned on holding off attaching the doors first. I wonder the reason for what he recommended.
~Jim
I removed my front bumper.
My Project Bolt
Today was a good day. My bolt is on wheel dollies and I was able to spin it around in my garage. This allowed me more room to remove my bed and dismantle it. Once that was done I stored it in my shed till a later date. I also gathered the wood for my cab dolly construction that will be underway shortly. I borrowed a heavy duty engine crane to remove my engine and transmission and am currently giving thought to the removal of my cab from the frame so i can send the frame to the sandblaster.
What about the rest of you?
My Project Bolt
Decided to start the truck today - it's been about 6 weeks. Let it run for about 45 minutes and all seemed good. My 38 has a 40 tailgate, so I took it off to have the lettering painted next week.
Today I removed the hood and Identified my engine as a 250ci strait six from a 73-79 chevrolet.
My Project Bolt
Today I positioned the engine crane in place so as soon as it warms up and dries a bit I can pull the motor and transmission.
My Project Bolt
Had a good day. A couple of guys (Gramps & Skip) from the Patriot Guard Riders came by to help. We got most of the cab disassmebled and the cab unbolted from the frame. photos from todays work.
Dave
www.fallenherosdreamride.org
all give some
MY SON GAVE ALL
The fallen hero's dream ride is a 1951 Chevrolet 3100 with original 216
In memory of LCpl Phillip Vinnedge USMC KIA 10/13/2010 Afghanistan
I gave the burb a road test today. 626 miles. It passed the test.
cletis did you drive it 626 miles today?
My Project Bolt
Yes I did. From home to Las Cruces, NM. Heading to Tucson tomorrow. More road tests.
Today I worked on the spaghetti bowl by the fuse block
http://i1136.photobucket.com/albums/n486/bobket/fuseblock004.jpg was looking for the cause for my brake light problem haven't found it yet but it looks like a new fuse block is in my future.http://i1136.photobucket.com/albums/n486/bobket/fuseblock004.jpg ,correction I found part of the problem
Fixed a couple of wiring glitches(my fault) blush
Now I've got the temp and oil pressure gauges working properly.....
The engine was an unknown quantity,so now I know the oil pressure's good,I'm a happy man!
More pix on Flickr.
The windshield went in on the second try. At first we tried to do it dry. Then we used dish detergent and it popped right in. I have the a/c compressor and alternator mounted and after making a custom bracket for the power steering pump everything lines up and none of the belts hit. Gauges are in, but not wired, as is the radio. New electric wiper motor installed and working. I’m waiting on Flaming River to complete the up-grades to my steering column. I am also waiting on the new brake pedal assembly so I can firewall mount the master cylinder.
’53 5 window
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
today I built my cab dolly. just have to put the wheels on it.
My Project Bolt
53 5 window
I checked out your slideshow John, it's looking real nice.
To quote the late great Frank Zappa regarding the glass install, "Keep it greasy and it'll go in easy!"
Although I'm not quite sure he was talking about glass! big_eek
More pix on Flickr.
had some coffee around 9:30 tonite and decided to go back out there and get the wheels on it.
My Project Bolt
Well after dinner I managed to get the new tubular engine mount fabbed in.Hoping to drop the engine in saturday.
Looks like you have a great bunch of mechanics there.
~Jim
Got almost half-way on the radiator. Not as easy as I thought, but it's getting the result I wanted. What's all that solder along the bottom? Was it born that way? Still lots to go, then tons of polishing.
Dale
Even tho it wasn't TODAY, it was recent and I just got the pics uploaded.
Sandblasted and painted my frame. HUGE step for me! Marks the "putting back together" of the truck.
Did all the work myself, my first time time to blast or paint on this scale.
#5 blastsand. PPG White epoxy primer. PPG gloss black enamel with hardener. 2 devilbiss startingline guns.
Like I said, my first time, so it's not pro but its not terrible. I'm happy with it.
http://i377.photobucket.com/albums/oo216/texaslocogringo/54%203100/Work/IMG_0550.jpg
http://i377.photobucket.com/albums/oo216/texaslocogringo/54%203100/Work/IMG_0549.jpg
http://i377.photobucket.com/albums/oo216/texaslocogringo/54%203100/Work/IMG_0531.jpg
http://i377.photobucket.com/albums/oo216/texaslocogringo/54%203100/Work/IMG_0494.jpg
'54 chevy 3100. In pieces now. .... I've always liked puzzles
-Gig em Aggies! Class of 2013
I removed my old pilot bushing, installed a new one and installed a new clutch disc. I am about to re-install the four speed after having it rebuilt. I am hoping that the tranny does not leak oil out the front shaft any more!
1951 1 Ton Completed
Leo Offline
Moderator
Moderator
Finished my passenger side door Monday, did the driver's side yesterday. When it was all finished, I saw the rain deflector on the bench. OOPS!! But its on now.
Thanks to several bolters for explaining a few details.
More sanding on the cab...........Pretty much the same as last weekend.
Dale
1949 Chevy 3100
More pix
I gave my mother great trouble but I think she liked it. ~ Mark Twain
Leo Offline
Moderator
Moderator
Dale
Same as next weekend too!
Finaly got my brake light problems fixed,eveything works at the same time.Now I can drive it at night again.
i unbolted my engine and transmission and tried to pull em out....didn't work. I have to find a better place to hook up the hoist for better weight distribution and level lifting.
My Project Bolt
My replacement rubber for my rear window came in today. That is my new replacement for my other new replacement rubber. I had tried and tried to install the window and in the process ripped the rubber. So, I get to try again. I think I've got it all figured out. I did this once when I was 17 but that was 51 years ago.
~Jim
Hello from Texas
i found a motor man said it was a 300 inline 6 gas gmc
Originally Posted by Billy_Beeson
Hello from Texas
Hello Billy, welcome to the Stovebolt.
You might want to post information about your new engine find in the "Engine" forum.
Also, if you don't have one find a cheap digital camera to post pics of your progress.
~Jim
