2 members (55shaker, Paul_WNC), 75 guests, and 1 robot.
Topics128,035
Posts1,055,552
#71374 01/09/2007 3:02 PM
Question? I now have both off my 250`s at home, and want to set one up in my 85 Chev pu. I am wondering what carb are people using with the stock manifold and a two bbl. What 2bbl is recommended? In addition does anyone run a th200r4 behind one of these. I know they are not as strong as a 700r4.
Thanks in advance and have some fun today.
Slider
Jesus is Love! Never forget the Veteran.
AND God bless Amercia!
#71375 01/09/2007 11:04 PM
Riding in the Passing Lane
If you have a 2 barrel carb. now you must have a intregal intake. That,s about as good a carb as you can get for that engine. The 200-4R trans. will hold up all right unless you do some serious hauling or towing, but I dought if it would be advantages with that engine unless you have a lower gear rear end then it came with. A 350 would probably work better.
1972 Chevy c10 Cheyenne Super
#71376 01/10/2007 1:07 AM
Z
Z Offline
the 200r4s are good if rebuilt by someone that knows how to modify it for strength.make sure to get the one with the dual pattern belhousing.
#71377 01/10/2007 1:32 AM
Both of my 250 engines have 1bbl carbs. I am wondering what 2bbl (common) is best to adapt to the stock manifold. Any advise will be appreciated. Thanks guys.
Slider
#71378 01/10/2007 3:41 AM
Junior Member
Junior Member
Get the adapter and Carter-Webber 2 bbl. carb from Tom Langdon StoveBolt Engine.
http://www.stoveboltengineco.com/acartpro/product.asp?productid=97
Just my Thoughts,
Walt
