8 members (Oswald, Bill Hanlon, Hanks custodian, gswbbc, cmayna, Otto Skorzeny, oldsteve, Stovebolt48),
129
Mod | | | Forums66 Topics128,042 Posts1,055,520 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#71374 01/09/2007 3:02 PM | Joined: Nov 2006 Posts: 61 Member | | Member Joined: Nov 2006 Posts: 61 | Question? I now have both off my 250`s at home, and want to set one up in my 85 Chev pu. I am wondering what carb are people using with the stock manifold and a two bbl. What 2bbl is recommended? In addition does anyone run a th200r4 behind one of these. I know they are not as strong as a 700r4.
Thanks in advance and have some fun today. Slider
Jesus is Love! Never forget the Veteran. AND God bless Amercia!
#71375 01/09/2007 11:04 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you have a 2 barrel carb. now you must have a intregal intake. That,s about as good a carb as you can get for that engine. The 200-4R trans. will hold up all right unless you do some serious hauling or towing, but I dought if it would be advantages with that engine unless you have a lower gear rear end then it came with. A 350 would probably work better. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#71376 01/10/2007 1:07 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | the 200r4s are good if rebuilt by someone that knows how to modify it for strength.make sure to get the one with the dual pattern belhousing. | | |
#71377 01/10/2007 1:32 AM | Joined: Nov 2006 Posts: 61 Member | | Member Joined: Nov 2006 Posts: 61 | Both of my 250 engines have 1bbl carbs. I am wondering what 2bbl (common) is best to adapt to the stock manifold. Any advise will be appreciated. Thanks guys. Slider
