| | | Forums66 Topics128,107 Posts1,056,225 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 4 New Guy | | New Guy Joined: Nov 2009 Posts: 4 | I have been referencing this great source of info for a year now and it sure has helped me along . Many thanks to All ! Bought this 1950 one ton Panel from a farmer in VA where it had been sitting for 12 years . I soon got the engine running and rewired it last winter . I am redoing the front end now and takling the king pins etc , I got the tie rod off the other day and noticed it has a distinct kink in it closer to the left side than the middle . Is this correct or has it been bent, probably whilst being towed at some stage ?! If so , can the rod be hammered straight again by somebody who knows what he is doing ? Thanks for advice . I will post pictures in the near future . | | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | yes it's been bent & yes it can be straightened by someone that knows what they're doing. | | | | | Joined: Nov 2009 Posts: 4 New Guy | | New Guy Joined: Nov 2009 Posts: 4 | Even upon closer inspection of the tie rod , I dont see any chain marks or gouges on it at the bend position . But thanks for letting me know and I will get it pounded straight by a machine shop .
1950 Chev 3800 Panel truck
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I think the bends are caused by a hard ditch or field hit I have seen quite a few of them bent usually about a foot or so in from the end on one side or the other. Some of these trucks certainly served their time before we end up with them. | | | | | Joined: Nov 2009 Posts: 4 New Guy | | New Guy Joined: Nov 2009 Posts: 4 | Got a machine shop to gently straighten the tie rod . We used a press and some carefully placed 1" pipe ( cut in half ) around the tie rod at the fulcrum point . After several presses , it was straight as it could be . I used the word "get it pounded" before and realize now that that would have ruined it , as it is hollow inside ! Onto the next job...........
