| | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#71283 01/07/2007 8:50 AM | Joined: Apr 2000 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2000 Posts: 81 | A friend of mine told me about someone with a 61 or 63 chevy truck that they unbolted the entire front suspension from a 76 or 77 chevy truck and did the same with the early truck. Then they were able to bolt the newer suspension onto the older truck. I've done some preliminary measurements and it looks like it might work. Anybody heard of this before?
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe 1947 Chev Coupe 1969 GTO ragtop
#71284 01/07/2007 10:40 AM | Joined: Dec 2006 Posts: 10 Junior Member | | Junior Member Joined: Dec 2006 Posts: 10 | I plan on the same thing. There is a lot of talk on this subject. I have a 60 swb to do. I have heard a rumor that some frames are wider; anybody have a thought on that? | | |
#71285 01/07/2007 3:14 PM | Joined: May 2006 Posts: 35 Junior Member | | Junior Member Joined: May 2006 Posts: 35 | i'm running the front and rear suspension from a '73 under mine.
i was going to type 'under my '66', but i'm in the process of merging the best parts of a '64 gmc shortbed and a '66 chevy big window fleet.
running the '73 rear on the '66 required drilling holes for new spring hangers, not required on the '64 since it was already set-up for leaf.
the front is a bolt in swap for both my '64 and my '66o ther than drilling some holes for sway bar mounts. i also moved over the power steering so i purchased the rez(?) conversion kit.
one other thing, i had to go to five lug rims.
bill graham
#71286 01/07/2007 4:41 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The 60-62 had a completely different system with tortion bars. I don,t think you can do it with those models. The 63 up should be an easy swap. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#71287 01/07/2007 7:05 PM | Joined: Dec 2006 Posts: 10 Junior Member | | Junior Member Joined: Dec 2006 Posts: 10 | I have spoken to other people with 60-62's, and they have done the same swap. | | |
#71288 01/07/2007 9:18 PM | Joined: Apr 2000 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2000 Posts: 81 | I have measured my frame on my 62 and so far it looks like a match to the newer frame. I had originally thought I'd have to do a frame swap. This is going to be less hassle by far. Answers like these are why I belong to this site
#71289 01/08/2007 5:36 AM | Joined: Dec 2006 Posts: 4 Junior Member | | Junior Member Joined: Dec 2006 Posts: 4 | I'm not sure about any other years, but my buddy put 1977 suspension on his 1966. He used the original springs from the 66 to lower it slightly. It was not really that hard, but having the right tools helped a lot. | | |
#71290 01/08/2007 8:52 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | As far as using a later front end under a '60-'63,I think the only difference you'd be dealing with once you pull your early suspension out is the crossmember the rear of the torsion bars attach to,and the only thing that ever affects is,sometimes,the exhaust system. Speed | | |
#71291 01/09/2007 11:33 PM | Joined: Dec 2006 Posts: 19 New Guy | | New Guy Joined: Dec 2006 Posts: 19 | Seen this on another thread, question, how about the brake gear, master cly, etc..
My other truck is a Ducati
#71292 01/10/2007 1:01 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | tea,the good brakes come with the new crossmember. www.mpbrakes.com can help you with the master cylinder. | | |
#71293 01/10/2007 5:11 PM | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | 6T2burb I bought a 1987 C20 IFS for my 51 and it was to wide for mine but I was told from several bolters that it would fit 60 thru 66 real good "almost a bolt in install" you'll have to drill a few extra holes in your frame. try to get the column from the donner truck also Good Luck Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | |
