1 members (5 Window 9434),
68
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | It would sure nice if the items you buy these days came with installation instructions. Ex. Does the rear window seal on an AD truck use the lock bead on the inside or out? The design of the bead makes sense to put it on the inside, but why then would the suppliers offer a choice between black or chrome? Or am I just stupid? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The chrome rear-window-seal retainer (lock bead) is for "dress-up" purposes. Chrome was not originally used. The retainers for all three rear windows are installed on the outer side (as described by Vern) in the same way (but only described in the Shop Manual for the "main" rear window).
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | The chrome rear-window-seal retainer (lock bead) is for "dress-up" purposes. Chrome was not originally used. The retainers for all three rear windows are installed on the outer side (as described by Vern) in the same way (but only described in the Shop Manual for the "main" rear window). If you mean by "chrome" the reveal moldings, on GM and Chevy trucks it came on 42 and 52,53,54 and on.
~Jim
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | If you are worried about theft, you can put it on the inside-the shop manual states it can be used on the inside if the truck has a body that prevents access to the back of the cab(like a box truck bed). | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The chrome rear-window-seal retainer (lock bead) is for "dress-up" purposes. Chrome was not originally used. The retainers for all three rear windows are installed on the outer side (as described by Vern) in the same way (but only described in the Shop Manual for the "main" rear window). If you mean by "chrome" the reveal moldings, on GM and Chevy trucks it came on 42 and 52,53,54 and on. They are referring to the lock bead for the rear windows and it never came in chrome from the factory. | | |
