0 members (), 151 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
#711650 01/14/2011 12:50 AM
From the off position I can turn the ignition switch clockwise two positions on and start. Shoudn't I be able to turn it one position counter clockwise from the off position for accessories.
no that how mine is. i don't have a acc position ccw.
The switches did not have a counter-clockwise position for accessories. The 2nd position, in the clockwise position, on some of the switches is the acc. position, but I don't think it was typical of the factory GM switches of the '60-'66 Chevy/GMC trucks, Panels or Suburbans.
I always heard if you left it on acc. say to listen to the radio, you could burn up the points.?
That is the whole point behind the ACC position. It supplies power to the radio and other devices but not the engine. If wired properly the ACC position will not supply power to the points so they are safe.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
there was no ACC position on the switches until after 67
Ya, I burnt up my points like that to, I also need solution for this problem. Newer switch, maybe? Don't know.
the "solution", if you feel the need to run the radio when the engine is off, is to rewire the radio so it gets power somewhere other than the keyed accessory power, then you can save your ignition [it can fry the coil as well as the points] and just run down your battery / shorten it's life .... or you could keep a portable battery radio around for those times wink
k10 Offline
Or get a Pertronix ignition!
Wouldn't another option be to put a toggle switch on the hot wire that goes from the ignition to the coil? Locate the switch in an accessible, but hidden, location in the cab and it could also be used as a theft deterent?
Fix one issue, get a bonus feature for your efforts.
What say ye guys?
In a nutshell a kill switch? Something i would consider doing myself to add to an option on my dash for a switch strip off the bottom of my dash!
62' GMC SWB Fleetside
Why can't we just go back to the designs from when cars were unique and didn't all look the same?
