3 members (Otto Skorzeny, 55shaker, ronsway), 71 guests, and 3 robots.
Topics128,077
Posts1,056,019
Members48,433
I have to do some major rust repair on the fram in the rear after removong the leaf spring brackets and crossmembers what is the best method to reinstall the brackets and crossmember can I use bolts or is there someplace to get the rivets and what size are they.
Deab
I think you can get about any rivet you would want from McMaster Carr but "setting" them properly may be a BIG job??
For bolts I'd use grade 8.
Just my .02.....I'm sure others will chip in more information.
Give this site a try:
Frame rivets
Thanks will give them a try
