| | | Forums66 Topics128,060 Posts1,055,835 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 66 | I have to do some major rust repair on the fram in the rear after removong the leaf spring brackets and crossmembers what is the best method to reinstall the brackets and crossmember can I use bolts or is there someplace to get the rivets and what size are they.
Deab | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I think you can get about any rivet you would want from McMaster Carr but "setting" them properly may be a BIG job?? For bolts I'd use grade 8.
Just my .02.....I'm sure others will chip in more information. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Give this site a try: Frame rivets | | | | | Joined: Dec 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 66 | Thanks will give them a try | | |
