1 members (68ironhead),
215
Mod | | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 53 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 53 | I am looking at what goes where on my truck and I see holes on the lower front face of my clutch housing(1950 Chevy 3100 1/2 ton with 216). There are 2 on each side. What gets bolted into these holes?
Also, on the drivers side there is a 1 1/2" hole. Does this just stay open, or is there a plug for it?
Dumb questions, but I have looked at the manuals and I could not find my answer. You guys are a lot of help. Thanks, Jerry | | | | | Joined: Dec 2010 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 24 | From inside the clutch housing 4 bolts attach it to the engine & from the outside two bolts across the top to the engine, not sure but I think the big hole is an inspection hole, also not sure about a plug.
'52 Chevy 3600 '03 Chevy 2500HD '64 Pontiac Grand Prix '93 Jeep Wrangler
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Clutch housing or bell housing????? | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Sounds like the clutch inspection cover bolt holes(2 pc) ?
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Dec 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 48 | The flywheel cover goes there. A 2 piece arrangement made of sheet metal. A dish shaped pan on the bottom called an underpan and a slightly v-shaped piece on the front by the oil pan called an extension. I would post pics but I need to get on the IT Short Bus. The hole is for timing. It should have a stainless steel pointed pin in it for setting the timing with a timing light. A rubber plug can go in there but it isn't necessary. Chevs of the 40's sells them.
1950 3804 Pickup
