3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#711143 01/12/2011 5:18 AM
I am looking at what goes where on my truck and I see holes on the lower front face of my clutch housing(1950 Chevy 3100 1/2 ton with 216). There are 2 on each side. What gets bolted into these holes?
Also, on the drivers side there is a 1 1/2" hole. Does this just stay open, or is there a plug for it?
Dumb questions, but I have looked at the manuals and I could not find my answer. You guys are a lot of help. Thanks, Jerry
Jerry M. #711149 01/12/2011 5:29 AM
From inside the clutch housing 4 bolts attach it to the engine & from the outside two bolts across the top to the engine, not sure but I think the big hole is an inspection hole, also not sure about a plug.
'52 Chevy 3600
'03 Chevy 2500HD
'64 Pontiac Grand Prix
'93 Jeep Wrangler
jacksont #711200 01/12/2011 4:03 PM
....I'm confused.
Achipmunk #711201 01/12/2011 4:11 PM
Pictures..?
Grigg #711206 01/12/2011 4:32 PM
Clutch housing or bell housing?????
dale937 #711215 01/12/2011 4:53 PM
Sounds like the clutch inspection cover bolt holes(2 pc) ?
Tim
1951 3100 Chevrolet
bowtietim #711244 01/12/2011 6:08 PM
The flywheel cover goes there. A 2 piece arrangement made of sheet metal. A dish shaped pan on the bottom called an underpan and a slightly v-shaped piece on the front by the oil pan called an extension. I would post pics but I need to get on the IT Short Bus. The hole is for timing. It should have a stainless steel pointed pin in it for setting the timing with a timing light. A rubber plug can go in there but it isn't necessary. Chevs of the 40's sells them.
1950 3804 Pickup
