7 members (JW51, TUTS 59, 3800GUY, Otto Skorzeny, cmayna, 52GMC35424JD, 1 invisible), 105 guests, and 5 robots.
Topics128,065
Posts1,055,863
Members48,428
#70983 01/02/2007 1:01 AM
I understand how a electric tach works but what about a cable tach???? how is it driven and will it work on my 1954 3100... Peter
#70984 01/02/2007 1:20 AM
Z
Z Offline
the cable tachs ive seen are hooked to the distributer
#70985 01/02/2007 1:25 AM
Early Corvettes used a fitting on the back of the generator for the tach, IIRC. Get a 54 Corvette generator for you 54 if that is the case.
#70986 01/02/2007 2:48 AM
electric tachs are much easier to install and work as good as a mechanical.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#70987 01/02/2007 10:00 PM
Stewart Warner has an adapter that goes between the distributor body and the cap with the drive for the tach in it.
