| | | Forums66 Topics128,007 Posts1,055,279 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 76 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 76 | Went to the shop tonight to sandblast a few small parts and the compressor won't run. Kinda cold here, 23 degrees, compreesor sits in non heated part of the barn. Could this have anything to do with it. Always ran before in cold weather. Checked and have power to it. It's a 220 volt unit. Any suggestions?
Mike
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | call Zim to bring over his hair dryer and warm things up  if it doesn't make any noise at all when you try to turn it on maybe the starting capacitor went south, if it does make some noise [click or hum] maybe there's some frozen moisture in the cylinders Bill | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | yea, you could take the belt off and see if motor itself runs and it's comp that's froze up. | | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | it 23 degrees!! its too cold for the machine, most compressors are indoor tools only
*UNDER CONSTRUCTION* 1953 Chevrolet 3100 1/2 ton-previously abandoned resto. My Project BoltI hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
| | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | All of my compressors are outside and cold doesn't affect them. I have seen single digit nights and teens during the day and it didn't affect the compressors. However if you have water in a line, it will freeze. I had one to pop a circuit breaker night before last when we had short sleeve weather. We took the belt off. The motor turns free, but it just hums. I ordered a new Baldor 10 HP single phase motor for $800. They are not worth trying to fix any more. | | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | i have a 60 gal upright and it says intended for indoor storage
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | It needs to be sheltered, but can be in cold storage. I can hear a difference when my compressor gets too much condensation in the tank. If you get too much condensation and it freezes, It will start to give you problems. Drain the tank regularly. | | | | | Joined: Oct 2006 Posts: 76 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 76 | Thanks for the replies. I put a little heat under the pressure switch and in a few moments it took off. Think i'll enclose it and add some heat. Thanks again guys.
Mike | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Glad you fixed your problem. I have my compressor in an unheated shop,and it gets pretty darn cold around here.In fact 23 is a warm temp. here in the winter. My compressor has never failed to run even in below zero temps.Dont know why. | | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | I dont know about you guys but I start and run a lot better when I am warm. Same for machinery - ideally keep it at constant 70F.
Refrigeration compressors have crank case heaters to reduce cold start problems - not only ambient "cold" I know.
Really big compressors and engines have circulating hot water and oil to ease starting and to allow "instant" loading.
Dan Bentler | | | | | Joined: Oct 2006 Posts: 76 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 76 | Hey Squeeze,
Zim told me I was more than welcome to his hair dryer.
Mike
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | The cold doesn't really affect it, BUT, you need the proper oil so it can start up even if the oil is cold. But if it ran before in the cold with the same oil, it is obviously not that. | | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | glad to hear its up and running again....and good point 1953panel I am sure this is often over looked but probably better to adjust your oil in the colder temps.
