2 members (Otto Skorzeny, Gdads51), 102 guests, and 1 robot.
Topics128,037
Posts1,055,580
#709533 01/06/2011 11:23 PM
My wiring was completely shot on my '48, so I am starting from scratch. Keep in mind it has a foot starter. While trying to re-wire the ignition switch, I used a tester to try to determine which terminal was which. But as I was testing, the only time I get a signal thru the switch is when I turn the thumb lever counter-clockwise. Isn't the conventional direction for an ignition switch clockwise? When I turn it clockwise the signal stops!
Also, I bought a couple of ballast resisitors, 1 for the ignition and 1 for the heater blower. They are 2 different brands. 1 reduces voltage to about 9 vt. The other shows 12 volts across both terminals. What am I missing?
do you have the two position or three position switch? Mine is three position and two of them is off. the one in the middle is on.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Ex Hall Monitor
Ex Hall Monitor
Wiring diagram. Click on the picture to enlarge. Your switch sure sounds backward to me but electricity makes my head hurt.
Presumably, you have a system that has been converted to 12v?
A ballast resistor is needed between the ignition and the coil. Other types of resistors (not ballast resistors, which usually reduce 12v to about 9v) will be needed with other 6v devices.
http://www.stovebolt.com/techtips/12_volt_conversion.html
Switch is 3 position, 3 terminal . No matter which terminal I use as hot, the other two are only hot when I turn the switch to the left. I am just afraid that I might inadvertantly leave the switch turned to the left when the truck is not running, and consequently burn up the points.
I have converted the system to 12 volts. I will now look for a voltage reducer for the blower.
Not to hi jack your thread but im working on a 1949 suburban its already been converted to 12v and has the original 216 with the key on then push the foot starter i am going to swap that out with a 292 and note sure if my key on the foot starter switch will work on that set up so if it doesnt what ignition switch do i need to get that i can put in the dash and have it key on key start?? Thanks
Stovebolt CHEVROLET
1949 Chevrolet Suburban
Non stovebolt CHEVROLET
1958 Impala Convertible
1963 Impala Convertible
MY 1949 SUBURBAN
headscratch
Stovebolt CHEVROLET
MY 1949 SUBURBAN
the answer to the foot start might be in this thread
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=559481&page=1
hopefully someone will chime in on what switch to use in your dash with your 292 conversion.
Good luck
