| | | Forums66 Topics128,162 Posts1,057,057 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 11 Apprentice | | Apprentice Joined: Feb 2000 Posts: 11 | Looking at buying a truck as described above. Would a '48 Chevy 3100 come from the factory with this shifter set up? I'd appreciate any replies.
I haven't been here in a long time since I had sold my '51 GMC 3/4 some time ago, but getting the itch to get back in the game. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't think they made such a setup. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | RPO 318B was available on 3100 trucks in 1947 & 1949 : H.D., 4 forward speeds (information shown in Truck Data Books). In both years, this was a "four-on-the floor". Most likely this was the same in 1948
As truckernix posted, a 4-on-the-column was not available from the factory.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The only column shift 4 speed that GM made that I'm aware of was the option 4 speed in the Corvair 95 trucks.
Bill Burmeister | | | | | Joined: Feb 2000 Posts: 11 Apprentice | | Apprentice Joined: Feb 2000 Posts: 11 | Thanks for the replies. The owner is listing the truck as having a "4 speed shifter [steering column shifter not floor]." I had never heard of such, and every 4 speed chevy of this era I've seen was on the floor. Either is is a very odd chevy, a modified chevy or an owner who is confused. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | an owner who is confused. Maybe he's counting reverse as one of the speed?
Bill Burmeister | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | That's exactly what I was thinking Bill.
| | | | | Joined: Aug 2005 Posts: 278 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 278 | longbox, never seen or heard of a corvair truck with column shift and doubt their existence. Column shift with the cab forward setup would have been difficult at best. Where did you come up with that info?
Thanks. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Could be a 700R4 and newer column. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Column shift with the cab forward setup would have been difficult at best. About every 60's era van I've ever seen had a 3 speed manual with a column shift. | | | | | Joined: Aug 2008 Posts: 82 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 82 | Not sure about Corvair vans, but some old Chevy vans had a four on the tree option.
1956 Chevy 3600 Dually
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Corvairs didn't have a column shift: period. The closest they came was the automatic shifter stuck out of the dash. Chevy vans, NONE with column shift manual 4 speeds, were popular with the three on the tree but remember the Corvair engine was just in front of the back bumper so running multiple shifter rods the length of the vehicle would have been impractical. A single rod run from the floor shift lever to the transaxle unit where the transmission sits at the very front. This rod rotated to select the gear and moved forward or back to engage them. Same setup was used on the 61,62 Pontiac Tempest IIRC, only the Tempest had the engine in the front with just the trans in the rear.
Evan
| | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | Well, you could do it. Just set up the four speeds 1+2, 3+4 on either side of the neutral gate. For reverse, shift into the neutral gate. You would need to create a dedicated push-pull cable to shift in and out of reverse.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Jul 2004 Posts: 2,991 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,991 | Don't know about American iron, but I know some of the foreigners did it. A friend of mine had a Saab with 4 on the tree. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | My uncle had a late 50's Mercedes with four on the tree, i drove it.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Aug 2008 Posts: 82 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 82 | Chevy vans, NONE with column shift manual 4 speeds, were popular with the three on the tree but remember the Corvair ... Not sure exactly what you are trying to say.. but Chevy vans did come with 4 on the tree. See top of page four of the PDF. I think these '60s Chevys sort of resemble the Corvair vans from the outside somewhat. I can see how someone could make a mistake in remembering what ride they were in forty years ago.
