1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Hey guys, Just installed new electric wipers on my truck cause all it dose is rain here. So they work great and I can adjust them on the wiper motor but one arm is always about 1 inch higher then the other. need to know if I can raise the drives side or lower the pass side wiper any. Thanks for the help guys. O ya Its on a 59 chevy Apache 31. Got the wipers kit from classic parts. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes, the arms can be removed and replaced where you need them. There is a little tab on the underside of the arm. Use a small prying tool to pull it away from the shaft and the arm will come off. | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | ok thanks. So its kind of like the new wipers, Or new wipers are kind of like it. I did not look at it to much but Ill look in the morning and see if I can get it addjusted. Sometimes its just easyer to ask then for me to mess it up. Thanks for the help. | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Even when it's obvious... sometimes it's not. Asking before you break something is the smart thing to do. Sometimes it just feels a little dumb... Don't know how many little things I've broken that would have been saved by a "stupid" question or a little research. Now when I enter the garage, I check my ego and pride at the door.... And count on the many wise men (and women) at the Stovebolt.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
