1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#708502 01/03/2011 9:16 PM
Hey guys,
Just installed new electric wipers on my truck cause all it dose is rain here. So they work great and I can adjust them on the wiper motor but one arm is always about 1 inch higher then the other. need to know if I can raise the drives side or lower the pass side wiper any. Thanks for the help guys. O ya Its on a 59 chevy Apache 31. Got the wipers kit from classic parts.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
Yes, the arms can be removed and replaced where you need them. There is a little tab on the underside of the arm. Use a small prying tool to pull it away from the shaft and the arm will come off.
ok thanks. So its kind of like the new wipers, Or new wipers are kind of like it. I did not look at it to much but Ill look in the morning and see if I can get it addjusted. Sometimes its just easyer to ask then for me to mess it up. Thanks for the help.
My YouTube:
Even when it's obvious... sometimes it's not. Asking before you break something is the smart thing to do. Sometimes it just feels a little dumb...
Don't know how many little things I've broken that would have been saved by a "stupid" question or a little research. Now when I enter the garage, I check my ego and pride at the door.... And count on the many wise men (and women) at the Stovebolt.
