4 members (TUTS 59, cmayna, klhansen, delwrench), 78 guests, and 4 robots.
Topics128,190
Posts1,057,223
Members48,465
Hello,
I have a non-running 1946 1.5 ton with a 160" wb. The shifter has a small lever attached to the side of the stick which has a rod that runs parallel to the stick and into the trans. It does not have a 2 speed rear, so is this some type of reverse lock out, a splitter, or a high/low range selector? Thanks.
46 Chevy 1 1/2 ton
The transmission is a 4 speed GM sliding gear. The trigger is a reverse lockout. All gears are sliding spur type gears that are not synchronized.
Great, thanks for the info. So a three speed would not have the lock out correct?
46 Chevy 1 1/2 ton
I may be wrong but I don't think 3 speeds were an option on 1.5 tons. The only ones I've seen were in half tons.for that era.
