| | | Forums66 Topics128,190 Posts1,057,223 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 34 New Guy | | New Guy Joined: Dec 2010 Posts: 34 | Hello, I have a non-running 1946 1.5 ton with a 160" wb. The shifter has a small lever attached to the side of the stick which has a rod that runs parallel to the stick and into the trans. It does not have a 2 speed rear, so is this some type of reverse lock out, a splitter, or a high/low range selector? Thanks.
46 Chevy 1 1/2 ton
| | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | The transmission is a 4 speed GM sliding gear. The trigger is a reverse lockout. All gears are sliding spur type gears that are not synchronized. | | | | | Joined: Dec 2010 Posts: 34 New Guy | | New Guy Joined: Dec 2010 Posts: 34 | Great, thanks for the info. So a three speed would not have the lock out correct?
46 Chevy 1 1/2 ton
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | I may be wrong but I don't think 3 speeds were an option on 1.5 tons. The only ones I've seen were in half tons.for that era.
