0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#707056 12/29/2010 9:36 AM
Need some ideas on how to accomplish some door art. Here's the goal - truck was just repainted. I want to put my logo on the doors, simple enough. But I also want it to look like someone had taken some previous door art off before I put my logo on. As I drive by, you don't really notice it, but if u stand there beside it in the parking lot, you can tell something was there before.
Anyone have any ideas on the best way to accomplish this? I've got some ideas but want to hear yours first.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
Yeah, put the stuff you want on, then sand it off then put the other stuff on that you really want.
Don't know why in the world you would want to do that to a fresh paint job in the first place.
DG
Denny G
Sandwich, IL
The reason, maybe a bit corny, is that I got inspired to do this truck based on a picture of my grandfather's lumberyard from just before WWII, they had a '46 1/2T as a delivery truck with their lettering on the door. I plan to make it look like (figuratively) that truck with the lettering removed and my logo put in it's place.
A good artist may be able to "shadow" it in??
This is just a WAG. Tape off the door as if you were going to paint the old logo on. Instead of using paint, use paint deglosser and allow it to dry. Then remove the tape. Perhaps this will give you the look you are looking for.
Good-luck.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
too late, you should have put the "old" logo on before the paint job and painted right over it wink
Good-luck.
Very close to what I was thinking but I like your idea better. I was thinking of applying a satin or flat clear (if there is such a thing).
Only other concept I could come up with was a color only slightly off of the base coat with clear for protection.
Can you clarify exactly what you mean here? A shadow of the outline of the letters or some other color over the current paint?
Thanks for the comments so far.
Found this - http://www.classictrucks.com/tech/1007clt_lettering_1929_ford_truck/index.html
interesting ideas.
And yes there is a flattener for clear coat.
....David
Green Farmer, I have a couple friends in the car club that have trucks with logos on the door that look both weathered and "painted over". Its just an artists "trick" that he does with mixing his paint and applying the design.
I use to do a lot of woodwork and I'd rub stain over nice white paint to get the distressed look ect ect. An artist does pretty much the same but does it as one picture he is painting. I must admit some guys are a lot better at it than others. Perhaps you can get someone to draw a rendition on paper to get the idea of what you want in the end.
Good luck, keep us posted and of coarse pictures of what you come up with.
