Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
9 members (oldsteve, Mr Bailey, cmayna, 216wny, baldeagle, frogfarmer, JW51, Peggy M, 1 invisible), 40 guests, and 1 robot.
Topics128,005
Posts1,055,261
Members48,418
#706063 12/24/2010 2:36 PM
I'm setting the 350/350 in my 38 today Doesn't the carburetor want to be level ?
1937 Chevy 1/2 ton panel
goneagain #706068 12/24/2010 2:54 PM
Apprentice
Apprentice
Yes.
The carb base should be lever. This will put the rear of the engine down just a bit.
Life is simpler if you plow around the stump.
50Deluxe #706077 12/24/2010 3:44 PM
Thank's
goneagain #706762 12/28/2010 1:11 AM
i thought the u joints were the main reason to get it level. the 292 i set up is 5 deg off level. not ideal but i wasn't going to to the mods to the get it straight. it 2 driveshafts so i hope it will be ok at less than 2 deg each. the carb angle doesn't seem to bother it. it runs well going uphill too so i wasn't worried about that.
I suppose having the carb reasonably level is a good idea...
But the critical part is the U-joint angles.
Here's a driveline setup tech tip with some good links.
http://www.stovebolt.com/techtips/driveline/setup/index.html
Likely you can have both a level carb (if it matters) and correct driveline angles, but no question about it I'd favor the correct driveline angles.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #706813 12/28/2010 6:26 AM
True - you can level the carb with an angled base plate (sort of an adapter milled at a shallow angle).
goneagain #707135 12/29/2010 6:45 PM
Apprentice
Apprentice
Most engines will have about a 3* angle down on the tail shaft when the carb base is level. Set the diff with the same angle up and you are right on for the d-shaft.
50Deluxe #707385 12/30/2010 5:27 PM
Just a thought, go to fuel injection and then you will only have to worry about the angle on the u-joints. Fuel injection doesn't care about engine angle.
Tim K #707740 12/31/2010 9:23 PM
Fuel injection costs a lot more money and I already have a carbureted engine.Besides blowers are more fun!
