1 members (baldeagle),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | I'm setting the 350/350 in my 38 today Doesn't the carburetor want to be level ?
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
| | | | | Joined: Mar 2007 Posts: 28 Apprentice | | Apprentice Joined: Mar 2007 Posts: 28 | Yes. The carb base should be lever. This will put the rear of the engine down just a bit.
Life is simpler if you plow around the stump.
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i thought the u joints were the main reason to get it level. the 292 i set up is 5 deg off level. not ideal but i wasn't going to to the mods to the get it straight. it 2 driveshafts so i hope it will be ok at less than 2 deg each. the carb angle doesn't seem to bother it. it runs well going uphill too so i wasn't worried about that. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I suppose having the carb reasonably level is a good idea... But the critical part is the U-joint angles. Here's a driveline setup tech tip with some good links. http://www.stovebolt.com/techtips/driveline/setup/index.htmlLikely you can have both a level carb (if it matters) and correct driveline angles, but no question about it I'd favor the correct driveline angles. Grigg | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | True - you can level the carb with an angled base plate (sort of an adapter milled at a shallow angle). | | | | | Joined: Mar 2007 Posts: 28 Apprentice | | Apprentice Joined: Mar 2007 Posts: 28 | Most engines will have about a 3* angle down on the tail shaft when the carb base is level. Set the diff with the same angle up and you are right on for the d-shaft.
| | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | Just a thought, go to fuel injection and then you will only have to worry about the angle on the u-joints. Fuel injection doesn't care about engine angle. | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | Fuel injection costs a lot more money and I already have a carbureted engine.Besides blowers are more fun!
