4 members (Southerntruck, 5cameo8, Jack Ryan, Bill Hanlon), 124 guests, and 2 robots.
Topics128,089
Posts1,056,418
Members48,443
1 Offline
Hey Everyone, first time post here. I'm looking for a wiring harness for a 1937 Chevy pickup, does anyone know of a reliable supplier for such a part?
Thanks in advance.
Ex Hall Monitor
Ex Hall Monitor
If you're looking for a cloth covered like the original I used YNZ. The cloth covered kits are expensive. You can get a modern harness from several different vendors. I've not used one so I can't speak about the quality or ease of installation. I did use a YNZ kit and loved it.
Check out the "links" at top of page. That will get you where ya' need to go.
Stock setup.....as above. Custom setup from many suppliers. I used Painless, but there are others like Hot Rod Wires, EZ Wire, etc.
1940 Chevy KC 1/2-Ton
I did my own. Used two different marine ATO fuse blocks, one for switched and one for unswitched. Use masking tape and a sharpie to mark the wires for different items. Fairly easy but time consuming, routing the wires so it looked nice was the most challenging. Used that plastic convoluted, split wire stuff.
Make sure you make a diagram of each fuse location on the block so you know what goes where.
1 Offline
thanks for all the help. I'm going to check out the links.
In the links you will find Rebel Wire. I've considered them all and it all boils down to what your going to be running.
...and Rebel will give you 15% discount as a stovebolter and their kits are not expensive to start with. I"ve used Painless, Rebel, and couple others. Lots of choices. Choose the one that suits your needs from any of them and I don't think you will be disappointed. The 37's are fairly straight forward.
I made my own harness.
