| | | Forums66 Topics128,066 Posts1,055,871 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | Messed up big time. Paint job is bad but still a fun truck to run,53, 3/4 ton 3600 Chevy.Blue painters tape Still on windows rubber. What's the best way to remove, please be kind,have taken a LOT of crap from the guy's and the paint job is a 100 ft.er. Getting too old for this stuff, but I'm still playing and having fun!!! Thanks, Paul | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | You'll need a solvent to release the tape glue. Grease and wax remover and lots of elbow grease! Paint thinner/reducer/acetone will work but if you get into your fresh paint you will cause another problem. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | How about trying some WD-40 I use it to remove decals a lot and it may just do the trick for tape?
red53pickup, just where you located in S.C.....or have I ask before. If your close to Spartanburg then its hot dog and Pepsi time!!! | | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | Thanks Achipmunk, I'm down here in Blythewood,15,miles north of Columba. Will try wd40 when it warms up a bit. Heard you might be getting snow,stay warm, Paul | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Think if the tape has been on there for that long, I would run a razor blade along the edge to cut the paint, you don't want it coming off with the tape. | | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | Right,that's what I started to do.Got a real nice paint job on the tape, wish the truck came out as well. Thanks Andy, Paul | | | | | Joined: Dec 2010 Posts: 44 New Guy | | New Guy Joined: Dec 2010 Posts: 44 | I am curious as to how your paint job is messed up. What happened, what type of system did you use(single stage, base coat/clear coat)? It is possible the paint job can be salvaged by water sanding and applying a light coat of the color and then clear coating. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Light heat from a heat gun or hair dryer should loosen the tape bond. Then the remaining adhesive can be removed with lacquer thinner or W.D. or whatever solvent works. | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Geez, don't be so hard on yourself Paul, Richard is right, you can probably fix nearly every sin in painting. Even the pros have issues. You know what they say, what makes a Master carpenter is one who can hide his mistakes the best! Good luck. I'll second the heat gun idea too, that works well. | | |
