3 members (GRNHydra, MRMEROTH11, Wally / Montana), 68 guests, and 3 robots.
Topics128,066
Posts1,055,876
Members48,428
#705876 12/23/2010 6:37 PM
Messed up big time. Paint job is bad but still a fun truck to run,53, 3/4 ton 3600 Chevy.Blue painters tape Still on windows rubber. What's the best way to remove, please be kind,have taken a LOT of crap from the guy's and the paint job is a 100 ft.er. Getting too old for this stuff, but I'm still playing and having fun!!! Thanks, Paul
Y
Y Offline
You'll need a solvent to release the tape glue. Grease and wax remover and lots of elbow grease! Paint thinner/reducer/acetone will work but if you get into your fresh paint you will cause another problem.
How about trying some WD-40 I use it to remove decals a lot and it may just do the trick for tape?
red53pickup, just where you located in S.C.....or have I ask before. If your close to Spartanburg then its hot dog and Pepsi time!!!
Achipmunk #705886 12/23/2010 7:25 PM
Thanks Achipmunk, I'm down here in Blythewood,15,miles north of Columba. Will try wd40 when it warms up a bit. Heard you might be getting snow,stay warm, Paul
Think if the tape has been on there for that long, I would run a razor blade along the edge to cut the paint, you don't want it coming off with the tape.
1946 Chevy 1/2-Ton
More pix on Photobucket
Sometimes I forget where I left myself....
andy46 #705925 12/23/2010 10:35 PM
Right,that's what I started to do.Got a real nice paint job on the tape, wish the truck came out as well. Thanks Andy, Paul
I am curious as to how your paint job is messed up. What happened, what type of system did you use(single stage, base coat/clear coat)? It is possible the paint job can be salvaged by water sanding and applying a light coat of the color and then clear coating.
Richard Morgan
1966 Chevy C10 LWB Stepside
Grandads_66 #706015 12/24/2010 4:10 AM
Light heat from a heat gun or hair dryer should loosen the tape bond.
Then the remaining adhesive can be removed with lacquer thinner or W.D. or whatever solvent works.
Geez, don't be so hard on yourself Paul, Richard is right, you can probably fix nearly every sin in painting.
Even the pros have issues.
You know what they say, what makes a Master carpenter is one who can hide his mistakes the best!
Good luck.
I'll second the heat gun idea too, that works well.
1946 Chevy 1/2-Ton
