| | | Forums66 Topics128,162 Posts1,056,933 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 46 | I would like to know what is the normal oil pressure is for a 1956 235 ci full pressure engine? And will I have to change my oil pressure gauge from the 0-30 to the 0-60 ?
Thanks Gerry | | | | | Joined: Feb 2010 Posts: 477 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 477 | My 62 235 (rebuilt) reads 40 on the block and 20 at the top of the head. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | 10-30 is about normal, I don't recall my 57 ever getting above about 30 on the gauge and it was a good engine w/ about 50,00 original miles
Chris - what RPMs and temps do you get those readings and what fitting on the head gives you a correct pressure? have you compared other gauges on that block fitting?
Bill | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | my rebuilt 59-235 runs 30 all the time. a hair higher when i first start it up, im using rotella 15-40. as for the gauge, you dont have to. i did just because i like to see the actual pressure on a properly spanned gauge. | | | | | Joined: Feb 2010 Posts: 477 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 477 | Temps. and RPMs don't seem to matter on mine, 40 on the block fitting and 20 on the head fitting that's at the top of the head. But it takes a little longer for the head pressure to build up. | | | | | Joined: Oct 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 46 | Thanks Guys But should I change my oil gauge from the max 30 to the max 60 one? | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | The maximum pressure is always going to be the relief valve pressure (unaffected by viscosity or temperature), unless there's something wrong. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A stock 30 PSI gauge holds up fine with a 235.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I would change it to 60lb gauge. My 1956 235 has a little over 40lbs of oil pressure at start up,until it warms up.
Tim
1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
