0 members (), 100 guests, and 2 robots.
Topics128,157
Posts1,056,875
Members48,456
I would like to know what is the normal oil pressure is for a 1956 235 ci full pressure engine? And will I have to change my oil pressure gauge from the 0-30 to the 0-60 ?
Thanks Gerry
1953 1-Ton Canadian Model 1434
More pix on Photobucket
My 62 235 (rebuilt) reads 40 on the block and 20 at the top of the head.
10-30 is about normal, I don't recall my 57 ever getting above about 30 on the gauge and it was a good engine w/ about 50,00 original miles
Chris - what RPMs and temps do you get those readings and what fitting on the head gives you a correct pressure? have you compared other gauges on that block fitting?
my rebuilt 59-235 runs 30 all the time. a hair higher when i first start it up, im using rotella 15-40. as for the gauge, you dont have to. i did just because i like to see the actual pressure on a properly spanned gauge.
Temps. and RPMs don't seem to matter on mine, 40 on the block fitting and 20 on the head fitting that's at the top of the head. But it takes a little longer for the head pressure to build up.
Thanks Guys But should I change my oil gauge from the max 30 to the max 60 one?
The maximum pressure is always going to be the relief valve pressure (unaffected by viscosity or temperature), unless there's something wrong.
A stock 30 PSI gauge holds up fine with a 235.
My Blog
I would change it to 60lb gauge. My 1956 235 has a little over 40lbs of oil pressure at start up,until it warms up.
Tim
1951 3100 Chevrolet
