2 members (delwrench, Maybellene), 99 guests, and 1 robot.
Topics128,176
Posts1,057,058
Members48,460
#704528 12/18/2010 6:46 PM
I'm trying to prep the steering wheel for the painter and need to fill and repair two cracks. New one cost $225.00 I'd like to repair this one. I searched the forums and came up with everything BUT steering wheel repairs.
Can a few of you give me some pointers. I'm searing the parts houses for the epoxy filler.
Jake
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
There are several "How to" videos on youtube, as they say a picture is worth a thousand words.
I used an epoxy meant for repairing plastic bumpers on cars. My brand is Dynatron. Like JB Weld with some flex, & sets up much quicker. I vee'd the crack using a Dremel, used my finger to smash the epoxy down into the groove. Sand, prime, sand, wet sand, paint.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Jake,
I've been thinking of using KBS epoxy putty for this project on my truck also. http://www.kbs-coatings.com/KBS-NuMetal-Epoxy-Putty_p_19.html Sure would like to know what you end up using and how it turns out.
Tom
1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
I found this on Youtube on the KBS stuff. I'm going to watch it a few times and will probaly give it a try. I'll take plenty of pics as usual.
pick up the feb 2011 issue of Streetrodder magazine, theres a good step by step article (page 152)of steering wheel restoration, they use a product called PC-7 A&B an epoxy for crack repairs.
1946 Chevy 1/2-Ton
More pix on Photobucket
Sometimes I forget where I left myself....
I have used other KBS products (rust remediation) and their products are top notch.
I have tried this twice and found that the application of the epoxy is very important. The first time I did it, I left extra epoxy, figuring I would sand it even. I am sure this is obvious to the experts, but when you sand two materials that are of different hardness you will run into difficulty. The epoxy resists sanding but the relatively soft hard rubber gets removed easily. You end up with "humps" of epoxy. The second time I tried this, I used a razor blade to level the epoxy, so little sanding would be required. This worked much better.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
I read somewhere here I think about JB weld putty. Not the 2 part tubes red cap and black cap you squeeze out but a putty with both parts resin and hardener in a plastic tube. I found it at advance auto. You slice the putty like cutting butter and mix the two. Then spread on the wheel and allow to harden. Then I sanded to shape and that was it. It has been on the wheel for over a year.
Rick..........
Check out this link:
http://www.secondchancegarage.com/public/475.cfm
They did a wheel for a corvette, but same idea. Very detailed and lots of pictures.
This is very soon down the road for me too!
What did you use to paint the wheel afterwards, just a plastic compatible spray paint? color?
Thanks for the link.
I used the steering wheel putty from any of the catalog shops - it worked out real well. Not rocket science at all.
Larry Bear
55.5 Chevy 3100 Panel
I went ahead and got a set of 2 part Por-15 epoxy and will attemp the repair this week end, will take pics as usually and doa Pro-Con write up.
Jake
Moderated by  ndkid275, Phak1
