1 members (ShopRag), 170 guests, and 3 robots.
Topics128,271
Posts1,058,314
Members48,485
#701449 12/07/2010 4:33 AM
How can you tell which end of the new rubber is up? I have a deluxe; does the SS trim around windows go on before installation or after?
Thanks.
On before you will never get it in right after.
What are you working on?
for your 51? if so
The Steele gasket I used has a cut out for the rear view mirror
Pic
install the glass in the gasket, then the ss trim, then install on truck
Check out CurtB pics in your earlier thread
https://www.stovebolt.com/ubbthread...Main=100384&Number=700707#Post700707
or this one
https://www.stovebolt.com/ubbthread...;Main=96618&Number=667666#Post667666
Good luck
9
9 Offline
redsil,
I didn't even notice that I had a deluxe rubber (it was used and I thought I would save the money) installed it and then realized that there is a groove for the "trim" So I bought trim. But yeah you have to put the trim in before you put the glass in.
Just be sure to put rope in your rubber, so when you place it on the cab, you just have someone push from the outside and you pull the rope, it pulls the rubber right over the lip perfectly.
So glass in rubber, trim in rubber, rope in rubber. apply
51' 3100 s10swap, 350, 5 speed, patina
http://67-72chevytrucks.com/vboard/showthread.php?t=382481
49' GMC 3100 future project
55.1' chevy future project
54' 6400 chevy dump truck all original
63' c-10 future project
