2 members (NJC, baldeagle),
33
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 7 New Guy | | New Guy Joined: Sep 2010 Posts: 7 | How can you tell which end of the new rubber is up? I have a deluxe; does the SS trim around windows go on before installation or after? Thanks. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | On before you will never get it in right after. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Apr 2010 Posts: 35 New Guy | | New Guy Joined: Apr 2010 Posts: 35 | redsil,
I didn't even notice that I had a deluxe rubber (it was used and I thought I would save the money) installed it and then realized that there is a groove for the "trim" So I bought trim. But yeah you have to put the trim in before you put the glass in.
Just be sure to put rope in your rubber, so when you place it on the cab, you just have someone push from the outside and you pull the rope, it pulls the rubber right over the lip perfectly.
So glass in rubber, trim in rubber, rope in rubber. apply | | |
