1 members (baldeagle),
42
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 27 'Bolter | | 'Bolter Joined: Jul 2010 Posts: 27 | question - will a running board off a 42 GMC 1 1/2 ton fit a 40 GMC 1 1/2 ton. | | | | | Joined: Nov 1995 Posts: 5,715 62401 | | 62401 Joined: Nov 1995 Posts: 5,715 | Texman ... They must all be poring over their Master Parts Catalogs to see if the parts numbers match...
Is it safe to assume that you need a running board for a '40 and you've found one from a '42? Any chance the seller will let you fit check, or is it an item that needs to be shipped to you?
Hopefully someone will be along who can answer this for you.
If not, give he guys at Jim Carter's a call (see our Links Page) -- somebody there might know.
Regards, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy texman, could you give us the series number of the truck so we can more precisely answer your question? Basically the running boards from 41 - 46 are the same, but there are different ones depending on the exact application, so series numbers will help a lot to clarify. | | | | | Joined: Jul 2010 Posts: 27 'Bolter | | 'Bolter Joined: Jul 2010 Posts: 27 | The numbers on the truck are AC 302 24060 .its a 1 1/2 ton GMC with a 9 foot pickup bed with huge rear fenders. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...not sure texman but I think 3B means is it a 30 series or 60 or 3600 or 3800.... I know these are for chevies but you get the idea. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy texman, okay with the series information I was able to confirm that they should interchange, the two trucks must have the same wheelbase, and of coarse they both must be pickup box type trucks. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Alvin, AC 302 is the designation for a GMC. | | |
