0 members (),
149
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 47 | What needs to be done when using a donor van column. The shaft is quite a bit shorter than the original. Can the van column be taken apart and shaft swapped w/ a non tilt shaft like below the tilt assembly ? Or add on to the shaft legth with a coupling or a repair sleeve. thanks
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | What truck you working on? ?? Most guys modifying the steering like the van column's be because they do tilt. If your street rodding and put power steering on it you'll need a double "D" shaft and couplings anyway. If I'm reading this right then I'd say add on to what you have.....or am I missing something? Just my .02 | | | | | Joined: Dec 2009 Posts: 194 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 194 | I used a column from CPP, it is easy to install, has tilt and all the hook up. I see lots of other ones and assume they all work about the same. You can order different length. | | | | | Joined: Apr 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 47 | Its a 65 c10, I am going to install power steering when I do this. I was reading that there are plastic rivets in the column that can be removed and the shaft will then slide in or out. I had the 2 columns removed sitting next to each other and the van column is shorter than the original. | | | | | Joined: Nov 2003 Posts: 70 New Guy | | New Guy Joined: Nov 2003 Posts: 70 | Find the shaft from a GM car or truck that goes between the van column and the power steering box. You can adjust the length of that piece by drilling out the plastic rivets. | | |
